I'm planning on using 1.25" copper piping to create 3 closet rods that extend from one wall of my closet to the other. On one wall, the stud is in the right place. On the other wall however, the stud is only in the corner and then the window framing gets in the way. And in case it matters, the wall in question slopes inwards 8 degrees.
What's the best way to attach the copper pipe to this wall? Should I just run three 2x4s off the corner stud? The problem with this approach is that the 2x4s would only be attached to that corner stud -- they won't cross another stud that I can secure them to as well.
Here's a picture so that you can see what that corner looks like with the window. In case it matters, the window is framed by 1x4s, and the framing protrudes from the wall (by around 0.75", or the width of the 1x4).
