Take the 2-minute tour ×
I'm under mounting a sink to a slab of granite and there many different brands of epoxy. Is one better for this type of job?
Just curious - are you using epoxy anchors or glue the sink directly to the slab? –  sharptooth Jan 31 '13 at 7:47
epoxy anchors is the plan –  Matt Jan 31 '13 at 19:09
add comment
up vote 3 down vote accepted
Absolutely not. Epoxies are formulated for different cure times, cure temperatures, bonding to different materials, performance in various extreme environments, etc. That said, amongst the various hardware store 5 minute general purpose epoxies, I doubt there is a lot of difference between brands. I know nothing of the specifics for this application, I would expect there is a specific adhesive to use and recommended by the sink manufacturer. If not, I would check with the stone supplier for recommendations.
+1. It's best to check with the sink manufacturer and/or stone supplier, to determine what product to use. –  Tester101 Jan 31 '13 at 13:14
add comment
