Tell me more ×
Last year, my wife and I purchased a house just south of Houston (Stafford, TX exactly). A couple of months into occupancy, we discovered that we had a problem with some Camponotus vicinus (Brown Carpenter Ant), and quickly got rid of them through the use of some boric acid and various other pesticides that were labeled for use against carpenter ants.
The thing about Camponotus vicinus is that they typically don't hit this far south and west, but I was able to confirm that's what they were by various sources around the internet.
Before you question on whether it's ants or termites, I can guarantee you that it's ants due to the piles of frass that they were leaving in a couple of places in the bathrooms, and I was able to grab a few and compare them to the ant/termite identification sheets found nearly everywhere.
But now we're starting to see swarmers of a different type of carpenter ant. These have the characteristics of Camponotus pennsylvanicus (Pennsylvania Carpenter Ant), but again, they don't really pose a threat to this part of the US. (See below)
I have removed the dead and rotting trees from my property, but I still need to trim some back. I also need to replace my soffits and facia boards on nearly the entire house to rid of that rotten wood, and I need to caulk around various pipes and such around the house.
I'm not terribly concerned about structural damage, but there's a lot of accessory damage that these things have and could do, and I want to make sure that's put to a stop.
My question(s) ultimately are as follows, though:
  1. Is there some other black or brown carpenter ant that would strike southeastern Texas?
  2. What is the most effective means of stopping swarmers of this sort?
  3. Are there any other tattle tale signs that I need to be looking for with these wretched things?
EDIT
I just got home from work a bit ago and caught a swarm in the master bathroom. Among this swarm were 3 or 4 queens and several other swarmers. The queens were about 5/8" in length, where the swarmers were all 3/8" or shorter.
I've ruled out Camponotus pennsylvanicus based on the appearance of the queens. Their head and thorax are brown, and their abdomen is a banded brownish black. They only have one pair of wings and these protrude from their thorax. They are single-noded, which leans more towards Camponotus vicinus again.
Once I get the pictures off my camera, I'll post them here for further identification.
EDIT 2
Here's a cropped close-up I was able to get of one of the queens.
A picture of one of the queens showing the most detail can be found here – Skudd Jan 29 at 1:50
I'm not an expert, but are you sure that's not a termite? – DA01 Jan 29 at 4:59
Positive. Check this out for more information. – Skudd Jan 29 at 12:48
1 Answer
Ants, and particularly carpenter ants, in wooded areas with plentiful food will be ubiquitous. If your property is sufficiently wooded it's likely that there are multiple colonies.
Carpenter ants are crafty, too. They are also hardier against poisons and pickier with baiting than other ants. When we had a problem with them I asked a few entomologists I know about their control. Their recommendation was that you must use multiple poison bait types. Carpenter ants will take protein (granules) or sugar (gel) baits based on their mood and the needs of the colony. You should supply both, regularly, around areas they frequent and around your home.
Look for products featuring Abamectin such as Advance Carpenter Ant Bait (that's "advance", not "advanced")
In sugar/gel baits look for products featuring Fipronil such as MaxForce Carpenter Ant Bait Gel
These products worked very well for me after vigilant application for a few weeks.
