A few years ago, some liquid (red wine or water from a plant) leaked on my hardwood floor (cherry). It took several months before we noticed it because it was under a carpet. This little incident left us with a very dark (almost black) stain of 4" in diameter (spawning across 3 planks).
Is there something I can use to diminish the appearance of the stain? Can I use some kind of bleach?
I would carefully try some oxygen bleach. By carefully, I mean not very long. Its not that caustic. If it looks like its going in the right direction, go a little longer. The kind I use is called StainSolver. The manufacturer recommends it for decks. You can find it with Google.
If you do end up going too far and getting the wood too light, you could try to match the original stain and re-stain it. – Doresoom Oct 27 '10 at 18:22
I don't really know if this will work, but since the only other option is chris's (replace or refinish the wood), you might as well give the bleach a try. If it fails, you're no worse off than before (unless you spill bleach over a much larger area) – Steve Armstrong Oct 28 '10 at 14:29
I tried regular bleach for 30 minutes with no noticable change. – Sly Nov 6 '10 at 2:41
I don't know if there's anything you can apply to the wood to restore it - I'd doubt it.
Your options at this point would be replacing the planks, sanding & refinishing the existing wood, or covering it up with a carpet :)
