My apologizes if I do not know the correct terminology for some of the parts. I will try my best though.
We have a Trane A/C system that is causing us a headache. It is causing water damage in our finished basement.
With our HVAC system the airflow is going downward through the unit, with the furnace on top, and the evaporator at the bottom of the unit. Our problem is that condensed water that is supposed to work its way down to the drain pan, instead fly off as random droplets of water and collect at the bottom where there is a large duct that goes from one side of the basement to the other where vents shoot off of that. So at the bottom of this duct the water slowly collects and eventually turns into a puddle and eventually it gets large enough that it will leak through holes in the ducting onto the drywall below it which covers the entire area (you don't see this duct). After time the water works it way through the drywall and then we have a mess.
The HVAC system was installed when the house was built in 2006 by a local company in the Seattle area that does HVAC systems. I believe this problem has actually occurred since the day that we moved in, but since in the Seattle area we do not get hot weather very often, and due to the fact the water had to work its way through the drywall, it took 2-3 years before the water worked its way through to even let me know the problem existed. I have since taken down the drywall around the leak and when looking at the drywall you can see numerous elliptical stains that look like they had been wet and then dried, that is my main reason I think the problem has been happening for a long time.
Unfortunately after 2 years the builder's warranty is no longer in affect, which I feel is unfair due to the fact this probably was most likely happening since the day I moved in. With that said we called the original installer to come out around two years ago to try and fix the problem. Initially they thought it was the drain tube that was clogged up, which it was a bit. So he cleaned that all out and I thought the problem was fixed. Sadly it was not, the problem immediately started happening shortly after their visit. I called them again to come out and this time he cut through on the bottom ducting to look up underside the evaporator and you could see that randomly every now and then a droplet of water seemed to have been flung off of the evaporator down to the hole where he cut. His solution was to cut a piece of sheet metal and put it underneath the sides of the evaporator a bit to hopefully collect the water and force it down into the pan where it would collect and then go out the drain tube. His solution did not work. His next statement I found hard to believe, but he said he thinks that dust is on the evaporator which is causing the water to not flow down properly into the dust pan. I looked up pictures of evaporators and to me this evaporator is about as clean as it can get. He basically said the next step would be to take the evaporator out and clean it for around $1000, or buy a new evaporator.
My question to you guys, do you think he is on the right track? I feel he has absolutely zero clues which is why I did not call him back after this visit because I did not want to waste my money. When I look up diagrams of evaporators it seems like every single one has the air going upward not downward with gravity. That made me wonder if the problem might actually be how they designed this with the airflow going down which combined with gravity might be enough to throw droplets of water off of the evaporator to collect below on the ducting. I have an image of a diagram which shows this, but need to wait until I get some more reputation to include that.
If the airflow was going upward, I could see it making it very hard for droplets to want to fall down since the airflow would be pushing it to stay on the evaporator where it slides down off on to the pan. Do you think this is part of the problem?
I have an image of how ours is designed and will include that later.
