Tell me more ×
Is there a standard (or a standard range for) the height and depth of each step in a flight of stairs?
If your answer refers to your building code, please say where you live.
up vote 7 down vote accepted
The general rule (in the US) is 7-11 (a 7 inch rise and 11 inch run). More exactly, 7 3/4 rise and an 11 1/2 inch run, although some people will use a run of as little as 9 inches.
You can find some more information here as well on other stair-related dimensions.
The Stairway Manufacturing Code Association published the International Residential Code in 2006 which tells you just about everything you could ever want to know about stairs, including:
  • minimum headroom depth (6' 8")
  • minimum tread depth (10")
  • maximum rise (7.75")
  • maximum tread depth variability (3/8")
  • maximum rise variability (3/8")
  • maximum slope of riser (30°)
Not what you asked, but for safety the most important thing, even more important IMO than getting the right rise and run, is that every step is consistent. Varying as little as 1/4 inch in rise will make even a ballerina fall on her face if she's running up the stairs.
According to Sheldon Cooper, it's 2mm :) – Doresoom Jul 22 '10 at 18:46
It not so much about the rise and run lengths specifically ,but about the ratio of the Rise to Run. You should strive to hit a 30-35% ration of rise/run. A 7-11 is the most common and gives you the correct ratio, but any combination of rise to run that hits this 30-35% ratio would be fine.
Within reason, of course. You wouldn't want stairs that are 2 feet tall. :) – aphoria Jul 23 '10 at 0:51
I've actually taken to taking two steps at a time so 2 feet may not be that bad for me ;) – Wayne Werner Jul 23 '10 at 4:06
@Wayne.. wouldn't that be a little close to three stairs at a time? :) – warren Jul 28 '10 at 19:54
