I am looking for a screwdriver. I want it to be powered (electric, cordless). I want it to not be based on a trigger mechanism (in order to reduce repetitive motion strain). I want it to screw (or unscrew with a switch) based on pressure applied (i.e. pushing down on the screw). I want the tips to be magnetic to grab the screw. Does such a tool exist?
Tell me more
closed as off topic by Niall C., Steven, mikes, ChrisF♦ Jan 10 at 22:21
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
Black & Decker GYRO might be worth a look |
