On what side of the furnace do I install the tank of the humidifier (the warm side or the return air side)?
Tell me more
All the humidifiers I've seen mount on the return plenum and have a duct installed that bypasses the air handler to the supply plenum. |
I've had two different whole-house humidifiers, both humidified the return (intake) side of the system, but in two different ways. One was a rotating disc system, which mounted on the bottom of the ceiling-mounted return; the discs rotated into the water and then up into the airflow. In our current house, the unit is mounted on a vertical surface of the hot side, and has a small pump that dribbles water down over a replaceable element; hot air from the supply side blows over the element it and back into the return duct through a small bypass duct. |
