My cabinet doors are tired and have many coats of ugly paint. Rather than strip all the paint off, I'm considering just chucking the old doors and making new ones. I like the plain style of just a simple, painted rectangle of plywood. But how can I finish the edges of plywood doors to conceal the plies so they don't shout "I am made of plywood"?
Tell me more
Try iron-on edge banding. Iron it on (you will have excess probably) and then trim the excess. You can usually get it pretty close to the color of your stain that you choose. |
You could use MDF. Much cheaper than cabinet grade plywood, and will finish up just fine with paint. |
What I have done in the past is routed the edges of the plywood with a round bit, then finish it with sandpaper and seal it with poly and/or stain. While it doesn't hide the layers, it ends up looking pretty good and it is safe. Sort of an industrial look. Just make sure you use a high RPM router with a sharp bit (and wear eye protection). |
A standard approach on shelving (which works on doors as well) is to glue a solid strip of wood to the edge.
