Take the 2-minute tour ×
What techniques work to dig layers of paint out of small slotted screw heads, when the slot is so full of paint a screwdriver won't work?
I've tried an awl, utility knife and screwdriver/hammer. These all work, but are tedious when there are a lot of them.
See also: How can I extract rusted/painted outdoor screws? or How do I remove calcification from a screw head?
add comment
up vote 2 down vote accepted
I've found that using a hot air paint stripper works.
Use the concentrating nozzle and a low to medium setting. Then when the paint is soft use a flat bladed screwdriver to first take the paint off the surface and then from the slot itself.
Once the head is free from paint a further heating of the screw will also help as there will be a differential expansion of the screw and hinge (or whatever the piece is) which helps loosen the screw.
A further trick I don't always remember is that it can help to try to tighten the screw first before removing it. This might just be enough to break the rust/paint/whatever is causing the screw to stick.
If you don't have a heat gun you can try a hairdryer set on high. Without the concentrator nozzle you may damage the paint around the screw. –  mikes Jan 9 '13 at 11:34
@mikes - yeah. However, usually I've been stripping all the paint so this isn't a problem. –  ChrisF Jan 9 '13 at 11:36
add comment
I have successfully removed paint from screw heads and slots by using a rotary tool with a small wire wheel attachment.
Be careful where you use one of these brushes. If you run it at too high a speed, or stress the brush too much, it'll throw off steel (stainless?) whiskers that are Supebly good at embedding themselves in feet or skin. –  Wayfaring Stranger Jan 9 '13 at 17:57
I like hte dremel for this, but I would use an abrasive blade instead of a wire wheel. –  Eric Gunnerson Jan 10 '13 at 5:26
add comment
