Tell me more ×
I'm going to be putting up some floating shelving. They are about 4" deep and 24" in length and the wood is 1" walnut. In order to hide hardware I was going to get 6 inch bolts (1/2 inch diameter). The bolt would go about 3 inches into the wall. The remaining 3" would be used to support the shelf. I would drill holes a bit larger than 1/2" in the wood.
Two questions:
  1. Does this sound feasible?
  2. If I get lag bolts, is it possible to cut the head off? What would be the best way to do that?
1 Answer
up vote 2 down vote accepted
Yes - It does sound feasible. A few things I would consider for cutting off the lag bolt heads.
1) Install the bolts first into the wall studs so you can utilize the heads for screwing in the bolts. Do not make the common mistake of forgetting to pre-drill a proper sized pilot hole for the lag bolt threads into the stud.
2) Use a reciprocating type saw (i.e. Sawzall) with a high quality metal cutting blade to cut the bolt heads off.
3) Dress up the cut bolt stubs to eliminate the sharp edges by using a Dremel type tool with a small grinder stone.
4) Only now mark the shelf pieces for the proper hole locations and drill your holes into the shelves.
Additional considerations -- --
A) A 4 x 24 inch shelf cannot get too much stuff on it. You may consider using a smaller size than 1/2 inch bolt and achieve a suitable result. A 1/2 inch lag into the edge of a stud has to be very carefully centered on the stud.
B) Consider safety factors regarding shelves that can simply pull off the wall mounted studs. You may want to consider the possibility of some type of set screw in from the top or bottom side of the shelf that would help clamp the shelf to the bolt studs. (You could of course glue the shelves to the bolt studs with construction adhesive but then the installation would be virtually permanent).
