How should I mount a TV stand on a wall covered in drywall? Should I trenail it to the wall?
How heavy is the TV you will be putting on it? Drywall may not be strong enough to hold it without using the wall studs. – chotchki Oct 15 '10 at 12:53
up vote 23 down vote accepted
I wouldn't hang my TV from the drywall. You really should put it in a stud.
+1 ... definitely should hit a stud ... even the flatscreen TV's are pretty weighty when it comes to drywall, it would probably eventually tear through the drywall. – user45 Oct 15 '10 at 13:52
Get an inexpensive stud finder or try using a knuckle or a small finish nail to find the studs. – BrianK Oct 15 '10 at 18:04
Depending on weight of the TV, you'll want to use at the very least something like a #10 2" screw into the studs. Often the wall mounts will come with even bigger lag screws (with a hex head) and again, those go into the studs. – gregmac Oct 24 '10 at 17:50
You MUST use a stud!!! End of story. – Bill Oct 18 '11 at 23:07
