I hear conflicting information on replacing the anode bar on a water heater or not since the water heater will be replaced anyway.
Should the anode bar be periodically replaced? Why? How often?
I hear conflicting information on replacing the anode bar on a water heater or not since the water heater will be replaced anyway. Should the anode bar be periodically replaced? Why? How often? |
The anode rod corrodes over time, and once it does, cold water is not properly delivered to the bottom of the heater which results in luke-warm water. The simple answer is that it should be replaced as-needed. On some water heaters, this rod is part of the cold water supply, so replacing it requires disconnecting the tank which can be a fair bit of work. Some heaters have what is known as a sacrificial anode rod that is independent to the intakes and exists solely to protect the rest of the water heater from corrosion - usually this one is easier to remove and replace. If you have plans to shortly replace the whole tank, I would not replace the rod unless you suspect it is already corroded and causing problems. |
The Anode rod is a sacrificial element that is there to prevent tank and water system corrosion. It's life is dependent on the type of water you are dealing with. Your tank's life is dependent on the rod having enough active material to erode away (cheap stuff like zinc or aluminum) through galvanic corrosion. If you don't mind the expense of replacing a water heater every 3-5 years, and possibly your hot side plumbing somewhere down the road just ignore the anode rod. One thing you don't want to skimp on is flushing the water heater regularly to remove particulate, rust and cast off spent anode rod material. If you have a copper water system, the junk can get out into the hot water piping where it can cause spot corrosion and nasty pin holes, destroying plumbing that could have lasted 40 or more years, all for the lack of a little maintenance. Been there on that one as well, it's far more expensive than the water heater and magnitudes more expensive than those damn rods that are there to prevent it in the first place. Proper life span says that if you can see the iron core rod in the anode, it needs to be replaced. Typically, for our water here, we can get 10 years on a water heater with about three rod replacements. |
