Tell me more ×
I'm mounting wifi in hallway ceiling; I have 110v in attic and plan on running Cat6 from structured media closet to supply internet. How do I wire for portable hard drive wifi backup? I believe it connects to the Apple wifi by USB and I don't want to put the hard drive in the attic? What wiring do I need from the wifi unit back to the closet?
closed as off topic by Steven, Niall C., Tester101 Jan 2 at 11:13
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
1 Answer
If you are just using a stand alone drive, no power adapter needed, then just run a USB cable into a closet near by or under to wireless adapter.
Not knowing your climate however choosing to put a device like an Access Point or Router in an attic sounds like a bad idea. These devices are sensitive to heat and cold and if you were living in a northern area these conditions likely won't allow your device to last as long as it should. To much heat in the summer and way to cold in the winter. Not to mention humidity control.
I would mount it all in a closet and run power and ethernet cables to the closet. This solves your hard drive placement problem as well.
I thought USB cables could not be that long? To make it back from the Apple Extreme to the closet would be about 15'-20' – user9860 Jan 2 at 3:06
