Tell me more ×
My furnace pilot light keeps going out. The furnace will come on and heat up to the degree set on my thermostat, then the pilot goes out and the furnace will not come back on. Could the thermostat be bad and cause the pilot light to go out? Is there anyway for me to check the problem myself?
Management of the pilot light is not within the thermostat's purview. It has nothing to do with it. It either calls for heat or not, the furnace does the rest. Sounds like you can successfully relight the pilot and it works until the furnace again runs, then shuts down? Then the thermocouple works, so I don't know what else could be the problem. – bcworkz Dec 30 '12 at 21:56
1 Answer
The thermocouple that verifies that the pilot light is burning (as opposed to releasing unburned gas) could be going bad. And you could also have either a blockage in your flue or a high temperature limit switch that detects or triggers a false positive that there's too much heat building up in your flue and shuts off the gas for safety. And finally, there could be a blockage in your pilot light itself that prevents it from properly working.
The first thing I would try replacing is the thermocouple.
