My new LG frontload washer leaves my clothes HOT after each cycle. The hot water valve has been turned off and it is still leaving them hot. Any suggestions?
Tell me more
If you're not selecting a hot water cycle, then you probably have the hot and cold water lines hooked up backwards. Or the hot and cold taps are labeled incorrectly. Next time you run a load, touch the water lines or the fittings to feel their temperature. If the cold water line is hotter than the hot water line, then you should be able to find the problem. |
