Tell me more ×
I'm installing a ceiling light to a fixture that was previously unused. However I'm having trouble because there are 2 groups of white wires. Which white wire should I connect with the white wire of my ceiling light? One group is a set of 3 wires and one group is a set of 2 wires.
Edit: I should also say that when I tried connecting the group with 2 white wires, turning off the switch for some reason short circuited the whole thing. I thought I might have done the grounding wire (the red one) wrong because I assumed I didn't connect the grounding wire. If my issue is not the white wires, can you please advise what else might be the issue?
Is this in the US? It's relevant because wiring is generally color coded but may not be coded the same in every country. – The Evil Greebo Dec 28 '12 at 12:50
I don't see enough information to explain what is happening. How many wires in total exist in the box, three wires with black, white, red and bare? Is the switch a two-way or three way switch? When the power is off on all switches that control this, do any of the wires still carry voltage? – maple_shaft Dec 28 '12 at 12:57
How was the old fixture connected? – Tester101 Dec 28 '12 at 13:26
The light has white, black and a copper wire. The picture is of the ceiling. Their was no prior fixture connected. I don't have a device that measures connectivity. – Chowza Dec 28 '12 at 22:13
Also this is in Canada – Chowza Dec 28 '12 at 22:14
1 Answer
up vote 2 down vote accepted
For the switch turned off to short things, it must be a 3 or 4 way switch. The 2 white and 2 black could be travelers, the most likely connection then is lamp black to switched power red, lamp white to the 3 white, probably neutral. It's worth buying a non-contact circuit tester, they aren't all that expensive and can be a literal life saver. You can then quickly locate the proper switched power and deduce which is the neutral, because my guess at what to connect is only a guess. The circuit tester will tell you for sure.
Thank you. Black to red and 3 white to white worked. – Chowza Dec 29 '12 at 18:15
