My garage remote recently stopped working. I recently replaced the remotes battery, and it did not fix the problem. I ran out of ideas how to troubleshoot this and would appreciate any advice with this.
First thing to try is re-pairing it with the controller. – Steven Dec 23 '12 at 23:47
Also the manual for your opener will likely have a troubleshooting section. – Steven Dec 24 '12 at 6:14
Check that you put the battery in the right way. Then use a multimeter to check its voltage and/or try a different known-good battery. Then I would follow Steven's advise to reset the code and check the manual. (You can likely find the manual online.)
Push the red button on the side of the opener.
When you push the button not only does it open the door, but it changes the frequency for the next push. If the transmitter and the receiver get out of sequence, the frequency will be off. The red button resets the cycle.
What does this do? – Niall C. Dec 25 '12 at 0:20
the way the remote works is that when you push the button not only does it open the door, but it changes the frequency for the next push. If the transmitter and the receiver get out of sequence, the freq will be off. the red button resets the cycle. hit the red button and then the remote. – Trout Jan 16 '13 at 19:36
What red button? Where is this located? – user47108 Dec 29 '15 at 19:46
protected by Community Dec 29 '15 at 20:13
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
