Tell me more ×
I'm working on a power station composed of three 800kva genset:
The power cable will be installed in four big tunnels for each phase I have 5 single core cables 300mm each.
Can I install phase L1 (5x300mm cables) in conduit #1 and L2(5x300mm cale) in the conduit #2 and phase L3(5x300mm) in conduit #3 and neutral (5x300mm cable) in conduit #5, or should I mixed the phases in a same conduit lets say for conduit #1 should contains (cables of phase 1,2 and 3) same for conduit #2, 3 and 4
Power station? Is this a commercial facility with high voltage? If so, this probably isn't the best place to get advice. – BMitch Dec 23 '12 at 14:32
You should consult someone licensed who has experience with this type of job. Not only because it's off topic for home improvement but it could potentially have a dangerous outcome – Steven Dec 24 '12 at 6:01
closed as off topic by Niall C., Steven, Tester101 Dec 26 '12 at 12:54
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
