Tell me more ×
In standard poured shower pan construction there is normally a rubber layer between the bottom flat layer, and the upper sloped layer.
Today I came across the following "updated" method:
redgaurd shower method (credit: Mr. Money Mustache)
I am under the impression that redgaurd is used primarily to keep splashes and overflow from causing an issue, and not as a primary water repellant.
Is redgard, or any comparable product, able to hold up under this kind of abuse?
1 Answer
Yes that is what RedGard is for (I assume you are planning to tile over the top of it). It is a waterproof membrane, it stops any water that might make it through the cracks in the tile (or grout). It is not intended to stand up to the abuse of a normal shower wall or floor so it must be covered with tile.
From the company's website:
Rated for extra heavy duty service
Meets Uniform Plumbing Code specifications for use as a shower pan liner
I used RedGard to waterpoof behind my tiles in my tub surround. It was pretty easy to work with.
@Tester101- I tried embedding them as "pictures from the web" but it did not work because Google does not expose the actual URL of the pic itself. When I get home I will upload the originals to SE. For now I will remove the links. – auujay Dec 21 '12 at 19:44
