Tell me more ×
After removing the carpet from our bathroom closet, I found urine stains on the plywood sub-floor (serenity now).
It sounds bad but the floors are quite sturdy so I'm reasonably certain that it's a superficial stain. What would be the recommended way of cleaning it (short of removing/replacing the sub-floor).
I'm planning to eventually place carpeting back in the closet so I'm not concerned with leaving a mark. Just want to make sure it's sanitary and odor-free.
-M
up vote 3 down vote accepted
I use Zep pet spotter, but it's intended for carpets, not wood. I think mop it with a dilute solution of chlorine bleach to sanitize the area, then seal it with a primer / sealer to prevent any residual odors from escaping.
Just an update -- primer/sealer seemed to work the best after trying a variety of different cleaning products. Thanks! – Mike B Oct 28 '10 at 16:29
What you want to look for are cleaners that are enzyme cleaners. These products actually break down the urine/biological waste. One example (that I use quite often) is Nature's Miracle.
I just love Nok Out.
I successfully removed cat urine odors from furniture, matresses and laminated flooring with it.
I would try oxygen bleach, in particular Stainsolver - see stainsolver.com. I'm not selling it, and in no way associated with it other than being a happy customer.
