Sign up ×
I am thinking of getting a Milwaukee M18 fuel drill/ driver combo. The drill is insane with 750in-lbf of torque. It comes with a hand tighten chuck though. My other Milwaukee corded screwdriver has a key tighten chuck and I like how tight I can get it.
My current drill (very old 9.6v Ni-Cad drill) has a 3/8in hand-tighten chuck. When I drill through steel with this chuck it comes loose. I'm not sure if more modern hand tighten chucks like the one on the M18 are better or not.
If I do get this new drill would it be worth it to get a new chuck, or would the one it comes with be sufficient?
up vote 11 down vote accepted
I have a hand-tighten chuck on my cordless (a Makita) and I've never had any issues. However most of my bits are spin-resistant (i.e. they have chamfers). I've used it with a step bit to drill 7/8" holes through stainless steel.
If that drill has a user-replaceable chuck, you could always just start with the stock one and upgrade if needed...
The drill you refer to has a single-ring chuck that is operated with one arm. Its surface is large enough so that you can have reliable grip and apply enough torque to the chuck to tighten/loosen it in all reasonable situations.
I've used a similar drill of another brand with the same chuck design - the chuck operation and reliability are just excellent. You don't need a keyed chuck instead of this one - a keyed chuck comes with risk of losing the key and with risk of injuring the hand should it slip while tightening.
Here is my two cents worth. A lot depends on the particular model and how it is used. My preference is keyless for 3/8" cordless drills and keyed for 1/2".
