Tell me more ×
I'm considering replacing the front door, and I'd like to know what to look for to get the most insulation. When shopping for doors, I'm not sure what I should be looking at to determine which doors will provide adequate insulation. I live in New York, so the winters can be quite cold.
What should I be looking at, to figure out if a door has adequate insulation?
Impossible to say what door would be 'best' for you. In general, though, simply look for 'insulated exterior doors'. They are typically steel or fiberglass exteriors with a foam-base core. – DA01 Dec 17 '12 at 3:02
1 Answer
All doors will come with a rated R-value or U-factor (sometimes called U-value). The higher the R-value the better the insulation. The lower the U-factor the better the insulation. Even doors that qualify for Energy Star certification come in a wide range of insulative capacity. I would simply go to your local lumber yard and speak there to a window/door salesperson. He or she will be willing to work with you to find a door or doors that fit your budget, aesthetic sensibilities, and desire for better insulated doors.
One thing to note - it doesn't matter how good the R-value of the slab if the door isn't installed properly with effective weatherstripping. Also note that at some point there will always be a compromise between the tightness of the fit and operability.
Here's a website that explains more about doors and insulation: http://www.green3dhome.com/YourHouse/Exterior/Doors.aspx
