Tell me more ×
An attic has been converted into a bedroom and it's very uncomfortable to sleep in, the air is very dry. I bought a humidifier but it didn't come with instructions. This may be a silly question but I want to make sure: how do I use the humidifier? I filled it with water and plugged it in. Nothing has happened after 30 minutes. A sticker on it says that if it doesn't work the first time to add salt to the water and to refer to the (non-existing) instructions. On the box it says warm mist vaporizer, are vaporizers the same thing as a humidifiers?
EDIT: I added salt and now it's going a little bit, hardly any steam is coming out of it, should there be more?
Was the attic converted by a contractor, or was it a DIY project? – Tester101 Dec 13 '12 at 13:30
Small appliances are considered off topic. Sounds like something you should call the manufacture about – Steven Dec 13 '12 at 14:22
@Tester101 yes it was a DIY and I suspect part of the problem is the insulation is not fully sealed off. Also the electric heaters really dry out the air. – Celeritas Dec 13 '12 at 22:11
@Celeritas You may be having problems with the space because it's improperly built. Attic additions are never as easy as they seem. In a lot of places you're not allowed to simply convert attic space to living space, you have to restructure and it's not as simple as building a livable box in the attic. Check local codes, and talk to local builders/contractors, they may be able to tell you why the space is so uncomfortable. – Tester101 Dec 14 '12 at 11:57
closed as off topic by Steven, Niall C., ChrisF Dec 13 '12 at 22:29
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
1 Answer
up vote 0 down vote accepted
I had to put salt in the water. After 10 minutes it started making a little steam and after 30 minutes it was making enough steam to actually notice a difference.
