Tell me more ×
We are staying in a home which has a concrete roof. Now we are facing leakage in the roof during rainy seasons. What do we have to do? How do we protect the roof from leaks?
As usual, you have to identify the damaged area and address the damage. – sharptooth Dec 11 '12 at 14:54
up vote 4 down vote accepted
Concrete itself is not waterproof, in fact, it's more like a sponge, so concrete alone is never used to create an impermeable surface. You haven't provided much info - is the roof flat, sloped? What is already up there? There are tons of different waterproofing methods available.
Going under the assumption that it was properly waterproofed at some point, you need to figure out why it's leaking. Maybe there is damage to the roof, or maybe there is a drainage problem and water is just building up and finding its way in. Also possible is that the flashing around a vent or access hole has been bent away and water is getting behind it. Either way, you will first need to investigate and resolve the root problem and then fix it in-line with how it was already constructed. If the roof is tarred, you are not going to put down some other barrier.
You will without a doubt have to go on the roof to check it out. If you're not comfortable with this, its best to call a roofing expert.
My roof is flat. I have an idea of roof weathering with tiles. Thus this will help? – Murali Dec 12 '12 at 5:38
If your roof is flat, you cannot waterproof it with tiles. You will need to go with one of the many options for flat roofing. There are many single-ply options, which are the best, there is modified bitumen (torch-down), and there is a typical tar and gravel type system that would suit your needs. Is there an existing roof system or is it just bare concrete? If it is bare, how old is this building? – Tim_P Dec 13 '12 at 2:51
Try Blue Bond with tile adhesive. Make it runny and apply it with a roller.
This seems to be a product specific to India. To make this answer more appropriate for the general audience, can you perhaps generalize the product type? Is there something unique about this product? – Steven Feb 7 at 3:26
