I've removed the tap and tried to reseat the pipe. I look in to see a large crack/split on end of the pipe.
Is there anyway I can fix this/reseal it with out ripping the house!
I've removed the tap and tried to reseat the pipe. I look in to see a large crack/split on end of the pipe. Is there anyway I can fix this/reseal it with out ripping the house! |
