I have a 50" x 36" laminated poster that has a propensity to curl. One copy of it curled so much that it bent the foamcore on which it was mounted. I decided to mount a different copy of it on a wood frame that I built. (The frame has four verticals and two horizontals, and is made of 3/4" square-cross-section sections of wood.) The frame is slightly smaller in both dimensions than the laminated poster. I would like to glue the poster to this frame, and hang the frame on the wall.
My question is what sort of glue to use that will bond the surface of the laminate (without damaging it) to the wood. I don't know what kind of plastic the laminate is made from.
UPDATE
Here is a picture of the frame overlaid on the poster (map). Obviously I plan to attach it to the rear :-)
