Tell me more ×
I find myself spending a fair amount of time in my workshop as a result of some newly acquired hobbies (painting an building things), and a seemingly equal amount of time in the kitchen as a result of long-held necessities (preparing and eating food). And as I don't like having paint-covered hands for cooking, raw-food covered hands for eating, or food-covered hands for working, I find myself spending a large amount of time washing and drying my hands.
In my quest to become more efficient, I'm trying to eliminate an obnoxious time sink: hand drying. Wet hands are an obvious no-go (chapped skin), and towels are either unsanitary (used) or incredibly wasteful (disposable). That leaves hand dryers, and though I'm pretty happy with the one I've bought (TOTO Clean Dry), it leaves me thinking that there has to be a faster way. Especially after learning about the Leidenfrost effect.
How should I go about creating or modifying a hand dryer to provide an intense burst of heat during the initial drying stages? I've experimented with foot-controlled 0.5 to 1.5 second propane bursts with some success, but it did singe a few hairs on my arm… and I'd hate to catch my sleeves on fire.
Are there faster ways to dry my hands than by using a high-pressure air dryer (like mine, Dyson Blade, etc)?
I wouldn't modify your hand dryer at all. Heat generating appliances are not thing you typically want to be modifying on your own. – DA01 Dec 6 '12 at 4:02
This is a bit crazy. Playing with large bursts of open propane flame merely to dry your hands is dangerous to you and potentially to others. One second of inattention will leave you with serious burns, or may kill someone else who inadvertently uses your contraption without knowing what you have done. If you are going back and forth so many dozens of times between places every day that the seconds spent drying your hands is truly a problem, then just arrange your schedule more carefully. – woodchips Dec 6 '12 at 13:35
Check out this: The airflow acts like a squeegee to pull the excess water off your skin, and then blow dries the rest. Probably expensive. They don't even quote a price on the website. – Chris Cudmore Dec 6 '12 at 13:41
-1 because this isn't something that anyone else should do... and from your past experience, neither should you. – BMitch Dec 6 '12 at 18:32
I fail to see how this is considered off-topic while there's a whole tag dedicated to dryers and other appliances.... but fair enough. I appreciate @woodchips suggestion, that's probably for the best. – JJ Caldwell Dec 7 '12 at 2:33
show 2 more comments
closed as off topic by Niall C., woodchips, ChrisF Dec 6 '12 at 21:14
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
up vote 4 down vote accepted
The Dyson Airblade and the Xlerator hand dryer are both really fast and effective. No need to reinvent the wheel.
Please see the faq for the rules on promoting products that you're affiliated with. – Niall C. Dec 6 '12 at 19:46
The TOTO Clean Dry is what I currently have and, while not as luxurious as the Airblade, it's equally fast. – JJ Caldwell Dec 7 '12 at 2:34
Get a box of cheap disposable vinyl gloves, like these, which are $40 for 1000 gloves. That way you won't have to wash paint, varnish, etc. off your hands as often. You could probably use them several times in most circumstances.
(If the disposability bothers you, consider that creating and using a custom hand-drier has its own environmental impact--the electricity (or propane) required to run it, plus all the embodied energy in the materials, trip to Home Depot to buy parts, etc.)
