I installed a new door that closes, but the door is too close to the frame on the bottom hinge side. This causes the bottom hinge to close completely before the door is closed, which leads to the hinge pulling out of the frame when the door is closed. How can I fix this hinge?
Additional background: I bought a solid core door. Trimmed .25" off one side. When I originally hung it, it fit perfectly. I took it down to paint, and now it's slightly warped on the bottom hinge side (less than .25"). Any ideas how to prevent warping? What paint and primer should I use?
Shirlocks answer is correct. I had a similar problem happen to me on a few door frames. After shimming the deep mortoise to raise the hinge a bit on the door, it closed fine. Also make sure that when you cut a door that when using a circular saw you make straight cuts using a saw guide attachment and clamp the door securely to a sawhorse. – maple_shaft Nov 29 '12 at 11:59
The problem with the hinge pulling out is caused by the mortise being too deep either on the door or frame. Look at both sides of the hinge and determine if one or both are recessed below the surface of the wood stock. Remove the offending side of the hinge and shim it out flush to the wood surface with some solid cardboard cut to fit the mortise. Reinstall the hinge over the shim. This should allow the hinge to close completely without putting pressure on the hinge screws.
As far as warping is concerned, that is not normal. Would have to see a pic or have a better description of the problem in order to address it. You mentioned cutting .25 inch off a side. How did you do that? If not cut perfectly straight, that may be a factor in your hinge problem.
I was typing a similar answer however you beat me to it. +1 – maple_shaft Nov 29 '12 at 11:52
@maple: sorry... lol... – shirlock homes Nov 29 '12 at 11:56
