We have a kitchen with a U shaped with a peninsula that divides the kitchen and the living room/dining room. If the end of the peninsula is against a black wall, how far up the wall do we stop the backsplash? I'm also assuming the backsplash will be stopped at the end of the counter top so it doesn't go into the dining room as well, right?
Hopefully I've given enough details to picture this.
closed as not constructive by The Evil Greebo, Steven, Doresoom, Tester101 Nov 27 '12 at 18:53
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, visit the help center for guidance.If this question can be reworded to fit the rules in the help center, please edit the question.
You stop it where it aesthetically looks good to stop it at. It's purely a subjective answer. – DA01 Nov 27 '12 at 7:21
A picture would help us picture what you're describing. – Tester101 Nov 27 '12 at 12:05
Backsplashes typically cover the area between the top of the countertop, and the bottom of the cabinets. If there are cabinets on the wall, use the bottom of the cabinets as a guide and carry that height across the entire wall (to the end of the counter). – Tester101 Nov 27 '12 at 12:10
-1 because this is getting close to decorating advice. – BMitch Nov 27 '12 at 13:19
The fact that it's subjective is quite a useful answer! The asker may have wondered if there was a code or a standard or even a rule-of-thumb. – Jeremy Stein Dec 3 '12 at 16:12
up vote 4 down vote accepted
from countertop to cabinet
As the rest have said, its purely aesthetic. On this side of the kitchen, we took the backsplash all the way to the underside of the top cabinets to fill in the space. Using different types of tile, we made a pattern that we continued on the opposite wall
no uppers
On this side of the kitchen that doesn't have upper cabinets, we stopped it at the top marble bar. The beige field tiles make up about 1 foot in height, with another 6 inches (ish) with the detail tile.
You can really do anything you'd like. There are many examples out there of styles and things you can do.
Thanks for the images! this helps a lot! – hellomello Nov 27 '12 at 18:30
A backsplash is there to be aesthetically pleasing and to provide an easy to clean and durable surface behind food preparation surfaces. It needs to go far up enough to catch the majority of splashes, say a couple of feet up, however past that is all a question of style. Some would say that it should stop at a couple of feet high and extend to the ends of the countertops, however I've seen splashbacks go up most of the way (or all the way) to the ceiling and extend way past the countertops. Partly it depends on what kind of money you want to spend: the more splashback you put in the more it will cost.
Thank you for your answer! This helped me get a feel as what I should do – hellomello Nov 27 '12 at 18:30
