I have a moncrief furnace and replaced the thermostat but the furnace will not cut off once it reaches the desired temperature. What could be wrong?
Tell me more
Home thermostats typically operate with a "dead band", a range above and below the set point that the furnace operates over. For example, if the setpoint is 68°F the furnace might turn on at 62°F and off at 71°F. |
