Sign up ×
I took off a hollow core interior door to paint it. Very thin coats (this is only the second time it's been painted since contractors built house. I know they only sprayed 1 very thin coat). Now the door doesn't seem to fit as well. I did new hinges -same size just different color. I know I can plane it for better fit but I want to know why the door doesn't fit right back in. The new coats of paint are not too thick so it's not the paint job. Ideas? I have more doors to redo so I want to avoid this problem again.
Were the hinges set properly? –  user558 Nov 25 '12 at 21:00
Any chance the door sat outside and was at a dramatically different temperature or humidity than the inside? –  Kellenjb Nov 25 '12 at 21:56
Did you buy heavy duty (thicker hinges) than the originals? –  mikes Nov 25 '12 at 22:05
You might be surprised how a couple of coats of paint can cause a close fitting door to bind. Where exactly is the door hitting the frame? –  shirlock homes Nov 25 '12 at 22:07
Can you describe how big the gap/overlap is along each side of the door to the frame? –  BMitch Nov 25 '12 at 22:17
You say
and this is a common misconception. Yes, it looks like the paint is negligibly thin but it actually adds up. When a door is constructed it has size that allow for painting it once, maybe twice, and then a new layer of paint will prevent it from closing.
You should have cleaned the previous paint off the door edges.
Since hollow core doors aren't made of the finest materials, is it possible that even your minimal amount of paint caused swelling? I could imagine that even just a bit of swelling over a 30 inch door width could cause it to jam.
