Tell me more ×
I am trying with humidity sensors and want to build a simple humidity circuit myself, I already got a USB humidifier dissembled, now I need a dehumidifier.
Can I make a small DIY dehumidifier with old computer cooling fins and fans?
If it is a silly choice, what would you suggest that I can build one from common backyard scraps?
This is probably more appropriate for electronics.stackexchange.com – Steven Nov 26 '12 at 3:31
How are you going to chill the heat sinks below the dew point so the water can condense? – Fiasco Labs Nov 26 '12 at 16:25
closed as off topic by Niall C., Steven, The Evil Greebo, DA01, Chris Cudmore Nov 29 '12 at 19:28
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
1 Answer
up vote 2 down vote accepted
@FiascoLabs brings up the key problem: The cooling fins and fan are good for cooling things that are above ambient temperature, but by themselves they can't cool below ambient temperature.
To dehumidify, you need to cool a surface below the dew point, which presumably is below ambient temperature. You will therefore need refrigeration, or a heat sink that is below the dew point (e.g. an ice bath).
You could pump ice water across the back of your cooling fins to get them below the dew point.
Exactly - The only time the dew point isn't lower than the ambient temperature is in foggy conditions. – The Evil Greebo Nov 26 '12 at 17:55
I think you have answered the question. And further asking should gets me into electronics or physics, I am accepting this. – Vicary Nov 28 '12 at 10:10
