I have a deep drilled well with supply lines split to feed the house and livestock watering respectively. The flow to the livestock line remains constant regardless of water usage in the house. But with everything turned off in the house except one faucet, when a toilet is flushed the flow from the faucet reduces to a trickle. Pressure at the well remains at 45 to 50 lbs. What's up? Also, whenever lightning strikes nearby, I get mud in house water. I'm perplexed.
Where is your pressure tank or do you have multiple pressure tanks?– dkwiebeNov 24, 2012 at 18:14
1Is this a new problem, or has it always been this way? What size pipes do you have in the house, particularly the main branch?– gregmacNov 24, 2012 at 20:50
1Are you sure it's lightning strikes, or perhaps just heavy rain? Surface water getting into your well is a serious concern.– bcworkzNov 24, 2012 at 22:39
1 Answer
My guess is there is a restriction in the line going to the house, with only enough getting through to feed one thing, either the toilet or the faucet. And since the toilet is probably drawing the water first before the faucet, it goes there.
I agree that it is more likely just heavy rain that is causing mud in your water. However, surface water getting into your water supply is bad news. You should consider adding filters to clean up the water supplied to the house. I'd guess a chlorine injector to kill any bacteria in the water, a tank to give the chlorine some time to do its job and let mud settle out, coupled with a filter that can take the remaining mud and chlorine out.
