When you install a tub, you try to build the surround such that water can't get through to the wall. That's great.
Nothing is perfect, and eventually small amounts of water will seep through. Then the water will be trapped in the wall or floor, and have a hard time getting out.
Is there a way to install a tub so it can dry out behind & underneath?
