I want to roll out some additional fiberglass insulation in my attic. Currently there is loose cellulose with faced fiberglass batts placed on top of the cellulose. The facing is facing out as in the picture. My question is, can i just roll the insulation out on top of this without a vapor issue or do i need to remove the facing (if that's even possible). Thanks for you thoughts.
