I live in a house with a septic system. When the winter/spring rains come, the toilet on the ground level master bedroom does not flush. We have another toilet on the ground floor that does flush. We have removed the non-flushing toilet, snaked the line and even installed a newer toilet. Nothing works until the ground dries out and then it will work fine. We had the septic tank pumped out, though it does tend to fill with ground water. What I don't understand is why will the one toilet work when the other will not? Any suggestions as to what the problem might be?
When you say it doesn't flush, can you elaborate a bit more? Is there no movement of water (overflows or fills up the bowl)? Does the water drain slowly without fully flushing? Does it gurgle? – Steven Nov 16 '12 at 3:13
Why does one toilet work and not the other? The working one is probably farther from the problem, giving it enough open, empty drain pipe to allow an occasional flush. As Steven hinted at in his answer, if you flush it enough times, it will eventually back up. – bcworkz Nov 17 '12 at 23:55
Septic System?? If so, the system is FULL of water already and needs to drain out from your drain field. If it is a municipal system, tree roots CAN SWELL TO 40 % or more of their normal size in wet weather, creating a blockage- hence a slower drainage- I'd look into a rooter service if this is the case and if on a Septic System- even pumping the tank will not help as the ground water is the culprit-preventing more water to disperse. Pumping the tank will only remove liquid & solids in the inlet side- not removing water from the leach/drain field.
Some possibilities, in no order:
Vent Blocked
The toilets vent becomes blocked somehow when it rains. Check the vents on your roof for obstructions like trees, plants, birds nests, etc.
Damaged Pipes or Tank
Water is entering your septic system when it rains though cracks in pipes, seals or the tank itself and overwhelms your leach field.
In this scenario, a backup in your house would seem likely to occur eventually. When you are having the flushing problem, check the lowest drains in your house to ensure the sewer is not backing up.
Failing Leach Field
Your leach field cannot handle the volume of fluid when the ground is wet due to rain and might need replacing.
As to why only one toilet is a problem, with the exception of the blocked vent scenario, it is hard to say. I would try flushing the working toilet over and over to see if it slows down or stops as this would help rule out that one fixture or a broader plumbing/septic problem.
I have the same problem. We do not have a septic tank but live in a town house condo. The level of toilet water gets very low when it's windy and when it's raining a lot it will not flush. The water goes down very slowly only. I understand the water level in the toilet is because of the vacuum that is caused by the wind over the vent pipe on the roof so I assume this also causes the flushing problem. I live with it however.
