Its been 6 months and I can't quite seem to find the parts I need for this.
I Need to attach a 1/2" OD (5/8" ID) tube to a 3/4" Copper Hydronic Baseboard Element. One end the Element is enlarged to connect to another copper pipe.
What I would like to do is find out what tools I need and what parts I need to connect the two together, preferably with quick connect fittings or whatever will not require expensive tools.
I'm using a 6" Baseboard Element to passively cool a large computer system, which appears to be work beautifully, but my current solution is not very good. It currently runs at about 2PSI and 5GPM, the pump is rated to 50PSI - so I'm reasonably certain there shouldn't be any flow problems.
Can you guys help me out? I have not worked much with plumbing, and I can't seem to find barbed reducer that will fit straight up. I also don't have a clue where to look for parts.
