Tell me more ×
I really want to replace our overwrought, baroque cabinet doors with flat panel doors. I want them to look good but I actually like the look of plywood.
It seems from what I've read like I have to use some kind of manufactured wood for that or it will warp. I've been looking at formaldehyde free maple or birch ply and wondering if that would be a good fit. I think I'm looking for A-grade maple ply, right?
The uppers are 30" high, the lowers are 23" high. The largest door is 30 x 21.
The existing doors use hinges that just require two bores in the door and can line up on the cabinet frame pretty easily, so I'm not worried about getting the hinges right. (and I already know I need a hinge cutter).
What else should I be concerned about?
What size are your doors. I deal with plywood cabinets all the time. – shirlock homes Nov 5 '12 at 23:10
Updated with dimensions. The largest door is ~30x21. The smallest is 15 x 15 – Amanda Nov 6 '12 at 12:50
1 Answer
up vote 1 down vote accepted
Your main concern is the wood warping. I've used plywood for cabinet doors in the past and they have all warped to one degree or another.
Your best bet might be getting marine ply which is designed to withstand moisture and hence less liable to warping.
If you can get a thicker ply (7 or 9 ply perhaps) then this will also minimise the amount it will bend.
How much warpage will be a problem depends on how large the doors are. Large full height pantry doors will warp some no matter what you use, the more common 2x3 foot doors will be fine with quality plywood. The other issue would be how the edges are finished. – bcworkz Nov 5 '12 at 23:03
I'm looking at Appleply, and I decided to pay someone with a woodshop and a drill press to cut and bore for me. – Amanda Jan 9 at 16:38
