Soon I will move from Europe to Canada and I am planning to take my TV and home cinema set with me.
TV is a Techwood (Samsung panel) LCD TV with the specs:
On the back of the TV it says: 220V-240V 50Hz 250W
The home theater set is a Yamaha YHT-394.
Written on the back of the receiver is: 230V 50Hz 250W
There is an active subwoofer with the set which states: 230V 50Hz 45W
Now the total is 545W so I assum that a 1000W step up converter is enough.
But will I get problems with the 50/60Hz conversion? NTSC/PAL is ofcourse not a problem anymore but I am a bit worried about the HZ (especially TV).
closed as off topic by Niall C., Steven, ChrisF Oct 30 '12 at 22:34
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
I'm not sure European audio systems are compatible with Geddy Lee – DA01 Oct 27 '12 at 6:22
up vote 1 down vote accepted
These electronics have rectifiers internally to turn the input into DC so the frequency won't make any noticeable difference. However, if your transformer is not "clean" then you are will get a lot of extra noise in your sound system; make sure it's a good one.
