Where can I find the exact part to replace my leaking electric water control valve module (has the source copper water line fitting) on my GE model 20-27 Refrigerator? Copper fitting is tight - not leaking.. The plastic valve module leaks - an electro-mechanical device
Tell me more
closed as off topic by Niall C., Steven, BMitch♦ Oct 29 '12 at 14:04
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
