We're installing an engineered wood flooring in a room that already has a plywood subfloor. The engineered flooring will be 1/4" shy of the height of the hardwood in the other rooms, so I'd like to make up that difference underneath. My original thought was to use 1/4" XPS but that seems like it may not work.
If I go the 1/4" plywood route, what kind of connection do I need between the two subfloors? Can I just float the 1/4" on top? Or do I need to affix them together? If the latter, would some 1/2" brads be enough? Do I need to glue and screw?
    I'd screw, not glue. Definitely not brads. Just enough screws to keep them in place, mind you, no need to go overboard
    – GdD
    Oct 24, 2012 at 20:51
Have you considered using cork as an underlayment? I believe they make them in various thicknesses, including 1/4". It's very easy to work with (you can cut it using a utility knife) and it helps dampen sound.
  • that's an interesting option! I'll need to look into that.
    – DA01
    Oct 27, 2012 at 18:26
  • I ended up using cork. It worked perfectly!
    – DA01
    Aug 19, 2020 at 19:08
You could simply install a transition piece between the two rooms.
But if you're determined to get them to match up, then 1/4" luann board will do nicely. Glue and screw - 1/4 bead of glue distributed evenly over each board, screws on a 1 foot grid.
NOT going overboard is what leads to squeaky, shifting sub-floors that make for a shoddy looking finished product.
  • screwing down some luann is fine, a layer of red rosin paper between layers will also avoid squeaks. I would put down some adhesive personally, takes out any bounce as well as squeaks. Oct 24, 2012 at 23:49
  • What about using a cork underlayment instead of luann? Since it's engineered, cork won't interfere with the attachment of the wood flooring. Plus it'd give a nice sound dampening effect.
    – Malfist
    Oct 25, 2012 at 14:19
  • I don't understand why it's being engineered vs. not engineered has any impact on the attachment of final flooring? Oct 25, 2012 at 14:49
  • I think he means it's a floating floor (because it's an engineered floor) so don't have to worry about glue/nails.
    – DA01
    Oct 27, 2012 at 18:27
  • Exactly, engineered wood floors are often floating floors and don't need to be nailed down.
    – Malfist
    Oct 29, 2012 at 12:18
