Still working on installing my exhaust fan. It required a dedicated 20A circuit so I ran #12 copper. The wiring from the unit appears to be #14 stranded. It's also silver colored but I don't know if that means it's aluminum. I need to connect one #12 wire to each of the #14s (so two wires per connector). What's the right connector to use for this?
That must be one powerful fan to require a dedicated 20 amp line. WOW. The silver wire you see is probably a tinned copper wire. (solder on the end of a stranded copper wire). To connect a 12 and 14 AWG set of wires together, you should use a yellow wirenut. If in fact the tinned conductor is smaller than a 14 AWG, you could use an orange wirenut. If you look on the package of wirenuts, it will give you a chart of the number and size of conductors the specific color wirenut will work with. |
You can also use whichever push-in connector makes sense for your application. I haven't had as good luck using them with stranded wire, but they are "allowed" and they do work.
More information is available at http://www.idealindustries.com/prodDetail.do?prodId=in-sure&div=0&l1=push-in |
