Tell me more ×
I have an electrical outlet which hasn't been reliable (the bottom one doesn't always have power unless you jiggle the plug), so I want to change it. I've changed a few plain outlets, but I found something new (to me!) when I went to remove it:
outlet
The wires run into the back of the box, as well as attach to the side. What is this called, and how do I remove them?
Is that green paint on the outlet? In the picture it looks surprisingly similar to the color of copper corrosion amd if this is not paint you have a bit of a mess to clean up. – Michael Karas Oct 22 '12 at 21:35
@MichaelKaras I checked, I think that's just the flash on my camera. The outlet appears to be clean. Thanks for the heads up. – MPelletier Oct 22 '12 at 21:43
up vote 13 down vote accepted
The holes in the back accept straight wire and are electrically connected directly to the screws on the side. The holes are a newer connection method while the screws are more traditional. Tightening the screws presses contacts against the wires in the holes and holds them in place.
In this case, you have a feed wire going to one and then continuing on to another place from the second. By the electrical code (at least in Ontario), you're not allowed to do this. You must connect the feed to the branch and to a short "stub" wire with a marette and then connect that stub wire to your outlet (either at the screw or through the hole in the back). Some people take short-cuts, however, and connect it this way to avoid the marettes.
Aside from that, I'll note that you have a "split circuit" outlet here. The top and bottom outlets are on different circuits, perhaps because it's a kitchen outlet and thus they must be split circuit (by the electrical code of Ontario, anyway -- your mileage may vary) or because one outlet (with the red wire) is "switched" by some wall switch. Make sure you break off the connector tabs between the two sockets on the new outlet so you don't accidentally short the two circuits together.
EDIT: As pointed out by @MichaelKaras, some outlets don't bind the straight-in wires with the screws but have spring-loaded clips that hold the wire and are released by inserting a small screwdriver into the square opening just above the hole.
EDIT: @MPelletier makes a great comment: US multi-wire circuits like that require either a double breaker or that the two breakers be yoked together so that you can't only turn off one. You might consider fixing the breaker box wiring for safety purposes. That's true in Canada as well.
It's in a kitchen alright. And close enough to Ontario (Quebec), so the electrical code might be similar. I tried unscrewing it. The suckers seem stuck in. I might as well snip them. And yes, I did notice the split circuit and had to turn off two switches in the breaker box. – MPelletier Oct 22 '12 at 21:21
@MPelletier - The poke in wires on that outlet are not secured via the screws. Instead they are retained by a spring clip inside that bites into the wire. To release the bite on the wire you have to insert a small flat blade screw driver into the rectangular hole right next to the wire. Press the blade in and possibly tip it to one side and the poke in wire should come free. Repeat for the other two wires. – Michael Karas Oct 22 '12 at 21:32
@MichaelKaras Only after sniping them did I notice the release slots. Big fail on me. – MPelletier Oct 22 '12 at 21:41
When you install the replacement outlet, if you care about secure, reliable, long lasting connections, you should consider using only the binding screws with a properly formed and oriented hook on the wire, rather than the poke-in connections. – bcworkz Oct 22 '12 at 21:47
@MPelletier US multi-wire circuits like that require either a double breaker or that the two breakers be yoked together so that you can't only turn off one. You might consider fixing the breaker box wiring for safety purposes. The next person might not be so observant. – Jeremy W. Sherman Oct 23 '12 at 21:04
show 6 more comments
This receptacle has "stab-in" connectors on it. The wire pushes in and is held in by a spring tab. To remove the wire, get a new piece of wire and strip off about 1-in. of insulation. Hold the wire with a pliers and push it into the rectangular hole below the stab in. That'll release the spring retainer.
These receptacles are known for intermittent failure because the spring retainer heats up and loses its spring tension.
As for whether this receptacle is up to code, here's what I see. It appears from the photo that the bonding tab has been removed from the brass colored screw connectors. This is usually done so either the top or bottom receptacle can be turned on or off by a switch. If the power to the top and bottom (even if one is switched) comes from the same breaker (just flip the breaker and if you lose power to both, then its on the same circuit), then both can share the same neutral (white) wire.
However, if the red and black wires are from different circuits, code requires that you hook the handles of both breakers together. That way, if one breaker overloads, it will turn off the 2nd circuit and not overload the single white wire.
