I have installed engineered hardwood all throughout my house, in addition wood base trim (which comes pre-primed). Now that my projects are done, I dont want to throw away the wood, incase I can use it for repairs or for a small future project, but its taking up space in my basement. Can I store the hardwood in my (non-climate controlled) shed, or will the varying weather/humidity render my wood useless for future projects?
I live in Maryland (winter hovers around 20 degrees f, and summers averaging around 90 degrees f) if that helps. The engineered wood is still boxed, the trim is not.
