Tell me more ×
I recently bought a house that was built in 1978, and it has a couple of garden faucets. These are not frost-free faucets, and that's not a huge concern for me because the house is located just south of Houston, TX.
What does concern me is that the one faucet needs some attention. The problems are:
  1. The valve seat is leaking, causing the faucet to drip
  2. The packing nut is leaking, causing the valve shaft to drip when the water is on
I've considered just replacing the faucet, which would be relatively easy, but after cutting a rag loose that was tied on with a shoelace, I found that the galvanized pipe feeding the faucet is pretty rusty.
I'm concerned that if I were to try to remove the faucet, the pipe would break or it may not come loose at all. I'm not too excited about attempting to replace the pipe, because it's also mortared into the brick, and I don't know how difficult it will be to get to the 90° elbow inside the wall either.
Should I decide to replace it, and assuming I'd need to replace the mortared pipe, how should I go about it?
Alternatively, should I decide to repair it, where can I get the parts I need to rebuild this faucet? The local Home Depot was of no use, and my Google searches don't seem to be specific enough.
Also, if pictures would help on this, I can get some up here tomorrow. – Skudd Oct 14 '12 at 2:14
Pictures always help. =) – Mike B Oct 14 '12 at 2:26
Generally, we frown upon shopping questions here. But, the overriding problem is interesting. I've edited it to make the question a bit more general, hoping to get some broader answers, and perhaps some assistance on replacing it. – Chris Cudmore Oct 15 '12 at 13:23
Check at a hardware store. They often sell a bag of faucet washers of a mix of sizes that can be used to repair your faucet. You pick out the one from the kit that suits your faucet.
Sometimes the hardware store will have a whole section of individual faucet repair parts. Take the faucet washer and stem seal with you to match them up with new parts.
On the other hand the garden faucets probably are available in only so many styles. You could take a picture of your existing leaky faucet and take it along with you to the hardware store or other big box type store and purchase a new one of the same or very similar style. Then take it apart to redeploy the rubber parts from it for use in your old faucet.
One addition to @Michael Karas advice. Try a small local hardware store before a big box store. The small local store is more likely to have what local builders used and what the neighborhood needs. The big stores tend to carry what sells nationaly and what they get the best price on.
