Tell me more ×
I will be tiling a tub/shower area using 8x10 ceramic tile with glass mosaic tile accent rows.
I see about half a dozen varieties of thin-set on the market:
Weights: - 25lb - 50lb
Types: - fortified - standard - flexbond
About every combination of the weights and types you can imagine is available.
What is the right thinset for my installation?
mosaics are difficult and experiment if you have not done this before. To much thinset and or to thin will ooze right thru. Even a dry mix will ooze. So build up and then use as little as will adhere the mosaic to the surface. Trush me, take one mosaic and test on a board or something. You can hose the test piece down later to reuse it. You need to see it for yourself to understand. – Tdd Apr 24 at 17:21
up vote 7 down vote accepted
Color
This is the easy one. If you're going to use dark grout, you can use grey thin-set. If your grout is a light color, or you're installing glass tile or a porous stone, use white thin-set. If you use grey thin-set with light grout, glass, or porous stone, the color may show through.
To modify, or not to modify
In most cases, you'll want to use some form of modified thin-set. Unmodified thin-sets are typically only used by professionals, and are modified at the time of mixing (using the pros secret recipe).
Standard
This is the economy thin-set. It will work well in most situations, and is a bit easier on the wallet. It should not be used with impervious materials such as glass, and porcelain.
Fortified
A fortified thinset like VersaBond®, is an "all-purpose" thin-set and an excellent choice for DIYers. It will provide a good bond between just about any tile and substrate you can use, and it's good for floors, walls, and counter tops.
Flexbond
Flexbond is a polymer modified thin-set. It is a good choice when working with porcelain or glass tile, or when tiling over a plywood subfloor. It provides a bit of extra flexibility, which can prevent cracking in some situations.
How much to buy
First you'll have to determine the square footage, of the area you'll be tiling. I'll use a tub surround with 2 walls 3' wide, one wall 5' wide, and tile 6' up each wall as an example.
The total length = 3' + 3' + 5' = 11'
height = 6'
sqft = 11' * 6' = 66 sqft.
I usually estimate that a 50lbs bag of thin-set will cover about 60sqft, so in my example I'll need 1 50lbs and 1 25lbs bag of thin-set. Don't worry, if you overbuy you can always return the 25lbs bag when you're done (just don't open it, unless you need it).
How much to mix
The bag of thin-set should list the Pot Life, which tells you how long the thin-set is good for once it's mixed and in a bucket. You want to mix only enough thin-set that you'll be able to use in this amount of time. This will depend on how fast you work, so you'll have to experiment to figure out what works best for you.
How much to spread
The bag should also list the Open Time, and Adjustment Time. Open time, is how long the thin-set can sit on the substrate after being troweled. Adjustment time is the amount of time after laying the tile, that the tile can be adjusted. In most cases you'll want to ignore these numbers, and simply spread only what you can use in 5-10 minutes. Again, this will depend on how fast you work, so you'll have to figure it out as you go.
Trowel Size
You want to make sure you get 100% coverage under tiles, which may require back-buttering on larger tiles. You also want to use a bit thicker mortar bed when setting floor tiles, since floor tiles may be subject to more abuse. This trowel guide from JAMO Inc., is a good baseline for which trowel to use.
Though you may find that you have to make slight adjustments, depending on the thin-set and tile you're working with.
So with a mix of ceramic and mosaic glass/stone tiles you would use Flexbond for the whole thing or flexbond just for the mosaic part and Fortified for the ceramic? Also with ceramic 8x10 and mosaic 12x probably anywhere from 3" to 9" (we'll be trimming it), a single square notch 1/4"x3/8" will do? – The Evil Greebo Oct 12 '12 at 13:35
Thank you so much for that trowel guide. – Chris Cudmore Oct 12 '12 at 13:40
Flexbond and Fortified are the same thing. They're polymer-modified thinsets, generally referred to as "modified" thinsets as opposed to "unmodified" cementitious thinsets. You generally want to use modified unless you have a specific reason not to, like DITRA or KERDI or large-format tiles. For the mosiac, which is usually thinner than body tile, you'll want to tile above and below the area where you're using the mosaic and use thinset to "build up" a little bit, let it harden, and then apply the mosaic to the built up area with the same thinset. – Karl Katzke Oct 12 '12 at 14:21
@KarlKatzke Flexbond and Fortified are different, sort of. They are both polymer-modified thin-sets, but the recipes are a bit different giving the Flexbond a bit more flexibility. – Tester101 Oct 12 '12 at 14:34
@TheEvilGreebo I'd use Fortified for the whole thing, unless you're tiling over plywood. And yes, I'd start with a 1/4"x3/8" trowel (but don't forget you might have to adjust depending on the coverage you're getting). – Tester101 Oct 12 '12 at 14:39
First off, you generally don't want standard mortar; the fortified ones are superior in most applications (though there are some cases where they don't work).
As for which fortified one, I'd spent time looking on the website information. If you can't decide, a polymer-modified thinset would work well. If you are going with glass tile accents, you probably want a white thinset because the color shows through.
You could also take your tiles to a tile store and ask them to sell you an appropriate thinset.
Can you elaborate at all on in what situations the fortified mortars don't work? What do fortified and flexbond mean? "Look on the website" and "ask a rep" isn't really much of an answer. – The Evil Greebo Oct 11 '12 at 12:43
Don't use thin set on a wall tile installation it isn't necessary. They make a very good adhesive premixed that has excellent bond and is much easier to apply to walls than thin-set. It's called mastic or tile mastic it comes in either one gallon or three and one half gallon buckets. Make sure to use a good backed board as well. Either hardi-backer or something comparable.
