Sign up ×
The previous owner of my house planted plants and small bushes where the drain field is.
I have a feeling that the roots will eventually damage the drains.
Is this okay or should I remove them?
Have a look at: see the do's and don'ts. –  Toon Krijthe Sep 17 '10 at 15:05
@Gamecat - you should summarise the main point (about which plants are OK) in an answer, referencing the source of course. –  ChrisF Sep 17 '10 at 21:11
up vote 2 down vote accepted
It really depends on what you want to plant, but generally you do not want to have anything but grass or something that has shallow roots and does not block out the sun. Your leech field works in two ways, one is the water leeches through the soil, but the other way that it works is evaporation. Evaporation accounts from 30 to 70% of what goes in your leech field, depending on how it is designed.
So I would avoid putting to much around it or over it. Trees will love the water, but eventually clog up your field. The worst, ficus trees, they should be called ficus weeds.
If they were called ficus weeds, nobody would want them in their office. I didn't know people planted those things outside, I thought they only grew under florescent lights. –  Tester101 Sep 22 '10 at 16:50
