Due to work on the heating pipes, the central heating water pressure is low. Is there a safe way to use the gas combination boiler (Ferroli Modena 80 E, domestic hot water + central heating) for domestic hot water production (until the end of the work on the heating pipes)?
Currently the low central heating pressure light is blinking (as it should) and the fire does not turn on when hot water taps are opened.
