Tell me more ×
I work for a kitchen joinery company and I am trying to find software that we could use for quoting and estimating. We are currently using Excel spreadsheets and I'm concerned that this is not a safe or stable process. We already use Cabmaster software but it is very slow if you only want to do a basic quote.
What programme can be used by joinery companies for this purpose?
Shopping recommendations like this are usually off topic on Stack Exchange. Questions about what tool can be used for a job are on topic here due to the nature of the subject. However, this doesn't fall into that category. – ChrisF Feb 1 at 8:54
closed as off topic by ChrisF Feb 1 at 8:54
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
1 Answer
Have a look at the TradeSoft solution called ProjectPAK. It will speed up your estimating and provides a stable platform. It has been developed specifically for the kitchen/ joinery industry. Depending on where you are located in the world, take a look at:
www.tradesoftinc.com or www.intermic.com.au/tradesoft
